goodluck...Trigger Happy said:ok guys, i finally!!! managed to get hold of a BP-200. this weekend i will try muko's suggestion to remove the screws instead of cutting away the battery insert section. i'll shelf the plan for added batteries in the grip for now. the plan is to link the shutter wires to the CD-ROM adaptor (cut already), with a branch for each of the three connections, to cater for a remote later on in the AA battery cavity. wish me luck!
Good luck. Keep us posted.Trigger Happy said:ok guys, i finally!!! managed to get hold of a BP-200. this weekend i will try muko's suggestion to remove the screws instead of cutting away the battery insert section. i'll shelf the plan for added batteries in the grip for now. the plan is to link the shutter wires to the CD-ROM adaptor (cut already), with a branch for each of the three connections, to cater for a remote later on in the AA battery cavity. wish me luck!
weikee said:i just got the BP200 in KL Mid valley for RM80around SGD 35
guRuh said:For you interest, I've used the Bp-220 from Canon
It's 13 cm in width, and I must say, it fits the 5D pretty well.
You have to drill or saw new holes though, not a lot of work.
Pics!
I love it :heart:
derelictz said:can i have one for my FZ-20 pls? :cry:
Trigger Happy said:first you need to figure out if your camera supports a remote cord/ cable.
then you need to figure out the pins (which combination focusses, which ones trigger the shutter)
THEN, to add to your headache, you've got to find a grip (any brand) that will sit nicely below your camera. the tripod screw is the centre point as that connects your camera to the grip. so just because both are same length/ width doesn't necessarily mean it will fit.
that's the easy part. now you need to operate on the thing and find out which cables in the grip focus and which combination (usually all 3) trigger the shutter release. then just follow my planning instructions above and cut/ solder away (of course the parts will be different for a FZ-20).
good luck!![]()
derelictz said:sounds very chim leh... muz be very adventurous...
