yoo.. thanks bro...greenieadi said:BP200 mod circuitry for shutter release and battery. Batteries from NP800.
For everyone's reference. (Including me!)![]()
do you know the circuitry?
can we make by ourselves?
i hate to disassemble NP800...
muko said:yoo.. thanks bro...
greenieadi said:One issue is the inventor uses 2 7.4v Li-ion batts but the input DC is 6V. The current is not an issue here but voltage is.
Normally a NimH rechargeable batts is rated at 1.2V, so meaning 1.2v x 5pcs = 6V.
I prefer to match voltage required by the equipment.
"External Power Source: 6 V DC (with AC adapter AC-11)" from manual.
Any thoughts anyone?
TME said:Sorry but I am a little confused here... how do you propose to connect the batteries in the grip to the camera? Via the external power supply jack?
muko said:S@!tt man...!!
Cannot find li ion batery in simlim...
need to order online...
guys... normally a power supply block has a regulator.. in this case is the 6v regulator...
plus... battery 7.4v is rating only and open circuit voltage.. if loaded sure will drop...
but too make sure about regulator need to check what is inside...
that is why if have such technical spec do let me know...
derelictz said:is it possible to do one for FZ-20? =X
wud like to have 1 of these...
greenieadi said:![]()
UPDATE : Formula for Output voltage should be this : Vout = Vin (1 + (R1/R2)) PLEASE NOTE !!!!!!
Hope this helps. The simplest type I know. Max input voltage is 35V, so I see no problem. Anyway, what output voltage should we set?
greenieadi said:U can use for the Pana FZ20 or any camera. Main purpose is to have constant desired output voltage.
muko brought up the issue of voltage drop with load, so this circuit should arrest the problem.
derelictz, I believe u can get the stuffs at Sim Lim Tower. If I'm free to go down, I will get stuff and do a protoype of the circuit. But don't wait for me. Anybody free can try lah.:sweat:
weikee said:If Vout = Vin x (1 + R1/R2), than Vout is always larger than Vin
what stupid things bro?weikee said:i try the 6v to the minolta 7hi, and it will not power up.. need to increase till 6.5v to power up the 7hi...and after some stupid things i did on the regulator, plug in and i blow the 7hi power board... and thats the end of my 7hilearn an expensive lesson.
Please use this to get variable voltage.
http://www.circuit-innovations.co.uk/LM317.html
