Riotbmx said:Agree. Using a flash with orange gel will not change the background because the light from the flash will never change the background. Someone mentioned this technique earlier, but that's for a different situation where the subject is slightly blue with the blue sky as background, using the flash with orange gel can correct the WB for the subject without turning the blue sky grey. But for TS case it's different, the people will look like lobsters and the background will still be blue if you shoot that way
Unagidon said:I think you made a mistake, using flash to correct wb between background and subject work this way.
If your subject has a warm tone and sky is daylight(neutral) by changing your subject into natural colour will turn your sky blue. So by using a blue gel, it neutralize the subject warm tone to neutral while sky remains.
If your subject has a cool tone and your back ground is daylight, you use a warm tone to balance it.
If your background has extreme blue tone use a blue tone flash gel, green use a green gel and yellow use a yellow gel so that you can tone the down colour when adjusting the wb.
Riotbmx said:Errrr actually I don't see where my mistake is leh. In my example the subject is bluish tone and the background sky is blue, using an orange gel flash will neutralise the subject and preserve the blue sky. Because using a screw on orange filter to adjust the white balance would means sacrificing the blue sky, so flash with orange gel would be ideal(other than photoshop) in that example. I don't shoot in colour but I'm always interested in learning about light, appreciate all the lessons here.
So back to TS' BBQ photo. So the background and the subject has 2 different tones and the camera and only set the WB to one, so can he set the WB to the background and correct the subject using flash? I haven't thought I this until now because I've always think I'm shooting film and forgot that TS can adjust the WB digitally.
Unagidon said:Haha i thought your subject is yellow if warm subject use warm flash gel sky will become super blue after correction. If its blue subject blue background just adjust wb digitally to more yellow prob solved. Yes he can adjust it using the flash method. I am also shooting film now but i like colour more but if my deduction is correct you also can do the same to film. Normal film is daylight (you can also get tungsten one like those lomo film with colour tone), using the same concept but use lens filter to balance up the colour just like adjusting it digitally and finally use flash to balance the rest. Sounds complicated but yet to try it out
would appreciate you guys can stay on the topic,
"the color temperature"
FYI, using flash is one of the solution,
since the background light source is daylight, flash is close to daylight, so you will able to blend the color temperature nicely, of course, you need to set camera white balance to daylight as well.
and one more thing, if you know how to use flash properly, you will able to get pleasing result with flash.
I believe what Catchlight said is correct; he is specific and explains.
To put it simply, the TS should set the WB to match the background, and use the flash to give the correct tone for the people shot.
ExplorerII said:But for some, using a flash on an M is not so cool leh.![]()
Of cos, to many it's just a fashion statement
But Eric Kim and Jacob Aue Sobol are using flash..and they look so cool !
NakhedCouture said:But Eric Kim and Jacob Aue Sobol are using flash..and they look so cool !
Eric Kim cool? I think he's making a fool of himself shooting flash right in ppl's faces.
virtualme78 said:Don't think its cool to say demeaning things about others just because you do not agree with the person's way of doing things. Some like it while the others hate it. Different strokes, different folks. That being said, I do not agree with shoot flash in other's face as well but I think the end result can be rather cool sometimes.
Not necessarily, you might end up mixing two concepts (white balance and fill flash) and creating a bigger mess.So i guess, my next step is to learn and play around with flash.
Riotbmx said:If he's making photographs by doing so I think it's fine, but randomly snapping at ppl's faces just to make a statement will only create a bad image for other photographers who document the streets. You have to respect your subjects
http://www.youtube.com/watch?v=9hXFVJELziw
virtualme78 said:I believe he respects his subjects as well just that the method he use to achieve what he wants seems a little offensive. There are other people who are doing the same. If I'm not wrong Bruce Gilden is the first to do that and Charlie Kirk is doing the same thing in Japan, even some of us in CS are experimenting it. Pretty sure most if not all of them respect their subjects (not sure about Bruce Gilden tho), just that getting that shot comes before the respect...
