Hiee Pals...
Here are some output tested on the 7D taken with the 1200AF-N macro ring flash. THis is the older one with the old flash controller. MAde to mount to the 7D with the help of the FS-1100. Yes its non TTL - full manual. Upon quick test, the X-synx speed max is 1/200sec.
Aperture size needs to be varied depend on magnification (distance to subject).
-1:1 would need aperture of f22/32 or more
-1:2 would need about f16/22
...ans so on..larger aperture as the magnification gets less - further away form subject.
FOr maximum TTL compatibility - the newer 3600-like controller is needed although the light ring can still be used.
Okay here are some early test shots..
Pre-conclusion ...it works perfectly with the 7D in full manual.
Will test out on the filed in a few days time..
rgds,
sulhan
rgds,
sulhan
