www.artworkfoto.com Camera,Lens,Filter,Flash,Tripod,Batterygrip...and more...
imgsize.php
Yongnuo YN465 TTL Flash for Nikon and Canon
Specifications:
* Guide number: 33
* Flash mode: TTL, M
* Circuit design: insulated gate bipolar transistor (IGBT)
* Vertical rotation angle: 0 to 90 degrees
* Horizontal rotation angle: 0 to 270 degrees
* Power: 4 x AA size batteries (alkaline or Ni-MH are usable)
* Recycle time: approximately 5s (AA alkaline cell used)
* Color temperature: 5,600K
* Flash time: 1/800 to 1/20,000s
* Flash control: TTL auto flash or manual Level 7 light quantity output control
* Dimensions: 72 x 135 x 85mm
* Net weight: 250g
* Accessories: flash light (1), protecting bag (1), and manual (1)
Note:
YN-465 for Nikon can only be used with Nikon i-TTL cameras (not compatible with D100 D50 D2Hs D2X D70 D2H)
YN-465 for Canon can only be used with Canon E-TTL cameras (not compatible to Canon A-TTL, and not compatible to Canon 5D, 5DII,1D, 1DS, 1DSI, 1DSII,1DSIII)
Available now at $135 with One Year Warranty!:)
www.artworkfoto.com
Your Reliable Photography Store:)
We are Physical Store,customers can walk in anytime.
Open from Monday to Saturday, 11AM to 8PM.
We are selling all items with price tag, you are SAVE:)
2 in 1 Fotopro Aluminium Tripod ( Tripod and Monopod)
Available now at $175, one year local warranty. :)
hi,
do you have the Aputure Trigmaster 3 in 1 Wireless Flash Trigger in stock?
thanks!
Now we are offering:
Free door to door delivery service for above $160 order
Above $160 value Order will be delivered to your door step(local only) even in the same day.
* Delivery order cut-off time is 11am for same day evening time delivery.
* After cut-off time order will be delivered on next working day.
* All order must through online first for proper record and confirmation.
* Payment must be completed via Ibanking upon confirmation of stock availability.
Thank you:)
Pixel TTL Trigger for Canon and Nikon Version 4 available in store now! :)
Tumax DPT386AFZ TTL Flash with LCD
For Panasonic and Olympus model available now at $190
For Canon and Nikon model available now at $165
Compatible Camera Model List!
Canon
5D,10D,20D,30D,300D,350D,400D,40D, 450D,1000D,500D,50D,5D Mark II,1D MarkIII,500D
G1,G2,G5,G6,PRO1,G7,G9,S5IS, G10,SX10IS,SX1 IS,Power Shot SX20 IS
Nikon & Fujiflim
D300,D200,D80,D70,D70S,D50,D40, D40x,D60,D700,D90,D3X,D3,D5000, D300S, D3000
FinePix S5 Pro/ FinePix IS Pro
Coolpix 4500, Coolpix 5000, Coolpix 5400, Coolpix 5700, Coolpix 8400, Coolpix 8700, Coolpix 8800, Coolpix P5000, Coolpix P6000
For Olympus and Panasonic
E-1,E3,E-330,E-410,E-500,E-510,E-520, E-420, E-620, E-30, E-P1
DMC-L10, DMC-L1, DMC-FZ50, DMC-LX3, DMC-G1, DMC-GH1
C-750UZ,C-770UZ,C-7070WZ,C-500Z,C-5050Z,C-5060Z,C-8080WZ
SPEED Lite YN560 Flash
Flash Specification:
Circuit design : Insulated Gate Bipolar Transistor(IGBT)
Guide Number : 58 meters (ISO 100, 105mm)
Flash mode : M, S1, S2
Zoom range : 24, 28, 35, 50, 70, 80, 105mm
Vertical rotation angle : -7~90 degrees
Horizontal rotation angle : 0~270 degrees
Power supply : 4×AA size batteries (Alkaline or Ni-MH areusable)
Recycle time : approx 0.5-3s
Color temperature : 5600k
Flash time : 1/200s~1/20000s
Flash control : 8 levels of output control (1/128~1/1), 57 levels of fine tuning
External interface : hot shoe, PC port and external power port
Wireless triggering distance : 20~30m indoor, 10~15m outdoor
Additional features
The electronic flash head zooming, sound indicator, automatically saving setting, PC port, power saving mode and over heat protection
Dimensions
60×190×78mm (Extended state) Exactly same as Canon 580EXII housing.
Net weight 350g
Acessories
Flash light(1), protecting bag(1), mini stand(1) and manual(1)
Suitable for:
NIKON, CANON, PENTAX, OLYMPUS
One Year Local Warranty, ready stock now at $140!
Thank you Mike. Great service & good stuffs!! :) :thumbsup: :thumbsup: :thumbsup: :thumbsup:
*Nikon model has no LCD, iTTL,iTTLBL,1/1,1/4,1/8 switches.
Macro Ring Flash DMAF 20 ETTL/ITTL For Canon and Nikon
• Guide No. 20 in meter,ISO 100
• ETTL/ITTL Control and manual out put
• Color Temperature:5600K
• Flash Duration : 1/1,000 to 1/20,000 second
• Model Assit Light (Super bright LED)
• Power ratio: from 1/1 to 1/4
• Both sides flash tube able to rotate 150 degrees
• Able to trigger both flashes or one flash(Left or right)
• Power source: 4AA size alkaline / Ni Cdmh battery
• IGBT circuitry for more flashes and fast recycle
• Virtually instant recycle times
• Recycling Time:0.3-5 secs
• 5 minutes auto cutoff mode
• Can be used with filter size : 49mm to 77mm
• Comes together with 67mm,72mm and 77mm adapter ring
Ready stock now, for Canon at $320, for Nikon at $260!
One Year warranty by Brilliant Singapore.
Fotopro 2 in 1 Carbon Fiber Tripod
2 in 1 Carbon Fiber MGC-584N Tripod
• CNC machined and harden anodized finishing body.
• 2 in 1 design,One leg can be released and used as a Monopod.
• Mode No:MGC-584N (Carbon Fibre tubes)
• Folded size:43cm
• Min operating H.:11cm
• Max operating H.:157cm
• Net weight:1.17kgs
• Loading capability:8kgs
• Max Tube:25mm diameter
• 4-section
Specification about Fotopro 51G Panhead
• Camera mounting screw:U1/4.
• Tripod mounting screw:U3/8.
• 36mm diameter ball.
• Product's size: 63*56*90mm
• Net weight:400grams.
• Max Loading Capacity:12kgs.
Professional tripods with newly technology of Forged body, CNC presicion machined and hardened anodized finishing.
G-lock system to extend and retract legs with ease.The third generation of 8-layer & 100% carbon firbe tubes for more lightweight and good perfermance works.
Now available again, Price $315!
I personally would recommend him to my friends and would like to say a BIG thank you for his very GOOD service and reasonable prices. Bought 3 PocketWizard Flex TT5 and some other items.
Thank you very much for your kind words bro:)
Hi,
Does the Sigma 50mm 1.4 have international warranty?
hi mchaint, i've tried purchasing the tianya GND filter from your website, seem to have some error. Might be browser inherent. do you still have stock for the item? i think i might drop by your store later
