WTSell: Tripod - Other Sirui tripod/monopod combo, N-2205 carbon tripod for travel
ernestt
221
3
18
Equipment Type: Tripod
Brand: Other
Short Description: Sirui tripod/monopod combo, N-2205 carbon tripod for travel
Price (S$): 220
Condition of Item(s): 9
The Sirui N-2205 5-section carbon fiber tripod is a great tripod for travelers and other adventurous photographers who need to pack extremely light and reserve the option to, at a moment’s notice, slim down their camera’s support system to just a monopo.
In excellent condition as you can see in the picture. No major dent or scratch. Spec is at the end of posting
It comes with everything in the pictures, including the tripod, soft bag, short center column, monopod mounting plate and screw, allen keys, and instruction guide.
Pls see pictures of actual item here
https://carousell.app.link/BQBNPo9Fwtb
Why it is good for travel?
Folded short at 43cm. Can fit in backpack or luggage.
Can convert to monopod if you want to travel even lighter.
Easy to set up and close with just half turn on the lock
Large leg diameter to ensure stability, with a little bit weight added.
The newer version is not as solidly made compared to this range of tripod any more. You spend less but get higher quality product.
The N-2205 features a leg that unscrews and attaches to a second included mounting plate and, optionally, the tripod’s removable center column, to form a monopod that ranges from 40 cm to 164 cm (with the center column attached).
Reaching a maximum height of 165 cm, the tripod is quite versatile in its own right. The N-2205 weighs just 1.3 kg but supports up to 12 kg thanks to its thick upper leg sections (only 3mm difference in diameter of each leg section).
The compact N-2205 tripod’s legs fold upward 180° around the tripod head to achieve a compact folded length.
Common - Material
Carbon
Tripod - Sections
5
Tripod - Max Diameter
28
Tripod - Min Diameter
Tripod - Min Height
14
Tripod - Max Height
142
Tripod - Max Height extended
165
Tripod - Retracted Height
50
Tripod - Folded Height
43.5
Common - Weight
1.3
Tripod - Max Load
12
Tripod - Head Included
No
Tripod - Monopod
Yes
Monopod - Max Height
164
Monopod - Min Height
39.7
9617886O
