get a Samson H2 Zoom (USD179) from ebay. Record from the speech podium. Much cheaper solution. You shoot with live audio.
If the mixer screws up and mixs the output with audio yr recording is trashed and you have no control and it happens once in a while.
Wish I have the flexibility of an additional recorder like what you mention. However, I think for my situation as a one-person do it all situation and kinda low budget all the time, it would take me additional time to re-synch those audios. Maybe that's the only bad point that I can think off..
Besides that, what additional pros would a wireless system have ?? hmmm... ??
Hi guys, if you are doing church wedding, the minimum I'll recommend is: 1 wireless mic on the groom, 1 mp3 recorder (with lapel mic on the podium), standard mounted mic on your cam. You only need to sync the podium recording once a while when you edit (takes a few minutes at most).
If you have the budget to improve the quality of your work, put 1 more mp3 recorder (with lapel mic) on the Paster and 1 more set on the Bride too.
Input from mixer can give you the best quality. But you'll leave your fate to the guy behind the mixer which you may not be familiar with. I'll try to lay a long XLR cable from the mixer whenever possible to the 3rd cam. But it is always a hit or miss.
Anyway, the sennheiser G2 wireless is becoming a standard equipment.
BTW, those mp3 recorders costs only S$100 off ebay, 1Gb storage and records to a 44.1KHz Wav file, with 3.5 mm mic/line in. Stereo lapel mics are cheaply avail too.
Now.. it gets me to think .. what advantage does the Wireless mic have as compared to this portable recorders.. with recorders we can get another channel of audio to play with . while with wireless we get to monitor the sound input.. we if like my case.. I just monitor thru looking at the audio levels, won't wanna wear another headphone running around.
Which is more consistent.. ..and i think both also risk kena stolen .. if we were to put the G2 at the PA system to get the line in from XLR .. it would be the same case as leave the portable recorder..
I think you misunderstood some stuff here... for me, a wireless mic gets close to the subject (without laying cables) and the audio gets recorded along with the visual (no need to sync in post). And each wireless input is more or less dedicated to 1 subject's audio. If I have the $, I'll not buy portable recorders. Instead, I'll buy 3-4 wireless mic sets and put them where I want to pick up the audio, plus 1 mixer (with 1 mixer guy to do live mixing of course!)
You still have to monitor your audio (via levels or headphones) regardless wireless or not (unless you set the recording device to auto. It's like your iris control for exposure).
On the risk of being stolen, I agree. But you got to be careful with all your equipment. I'm often lucky enough to have people returning my stuff to me even before I went to dismantle.
Hi Alternus, I have always been thinking how is it possible to mic a bride in her gown. Have u ever attempted that?
Lapel on the pastor or mp3 podium is a must. The groom alone is usually insufficient.
Got to embed the mic in the gown before she wears it.... can't fix a wireless on her. Has to be an MP3. For angmoh brides, they have a garter on her thigh to hook on. SG brides? use the Cancan lor... haha!
I've yet to try that. But hope to try it out soon. Best to use a white/beige lavaliere. But they are not really affordable to me.
Bride is always difficult to mic because of the dress she's wearing.
My solution when I was doing wedding coverage donkey years ago.....get an omni pattern wireless mic on the groom....when they face each other to do their vows, both bride and groom will be adequately picked up on the wireless omni lapel mic.
If you use a cardiod pattern lapel mic, then you can forget about picking up the bride's speech effectively if the mic is on the groom.
1 shotgun on cam, 1 wireless omni on groom is usually quite sufficient for me.
If clients are anal about audio and want better quality, I will increase budget and get a sound man.
Another solution is to use your wireless kit, tap a line out from the FOH mixer. One channel on boom & another on wireless line out from mixer. :thumbsup:
