RedDotPhoto
The most important part of a AA battery system is the charger. Get the best of the best from Maha (USA) with the following great value packages:
Maha PowerRex MH-C9000 Battery Charger by Red Dot Photo
Maha PowerRex MH -C801D Battery Charger by Red Dot Photo
Maha PowerRex MH-C401FS Battery Charger by Red Dot Photo
Maha PowerRex MH-C204 Battery Charger by Red Dot Photo
MH-C401FS, $65
The MH-C401FS is also the first charger on the market to offer the choice between a 100-minute rapid charge and a slower, gentler 5-hour charge, both driven by a microprocessor termination control to prevent overcharge. Accomplished by simply flipping a switch, the 5 hour gentle charge achieves ultra-cool charging when charging time is not crucial.
* 100 Minute Rapid Charge Microprocessor Cutoff
* 5 Hour Gentle Charge Microprocessor Cutoff
Advantage: Extremely fast recharge time
Advantage: Cooler battery charging and extends overall battery life.
Only $65 including 4 powerex Imedion batteries!
__________________________________________________ __________________________________________________
MH-C801D, $140
The MH-C801D features
8 Independent Charging Circuits
EIGHT independent circuits that charge ONE to EIGHT AA or AAA batteries in any combination.
Selectable Soft and Rapid Charge Modes
The MH-C801D provides user with the option to choose between a soft charge and a fast charge mode. The soft charge delivers the highest battery life and allows 100% compatibility with older, lower capacity batteries. The fast charge allows eight batteries to be fully charged to their maximum capacity in around one hour!
Ultra Fast Recharge Time
Recharge in 1 hour regardless of number of batteries in normal mode. In Soft Charging Mode, recharges in two hours.
Only $140 with 8 Powerex Imedion batteries!!
The most extensive charger ever! The MH-C9000, $105
Four independent slots
It's like having four charger-analyzers for AA and AAA NiMH / NiCD batteries.
Large backlit LCD display
Digitally displays capacity, voltage, time and current.
Endless programming possibilities - over 10,000 ways!
29 selectable charging and discharging rate. Charging current from 0.2A to 2.0A and discharging current from 0.1A to 1.0A in 0.1A increments.
Five modes of operation
* Charge: Recharges the battery at the selected rate. Suitable for batteries used frequently.
* Refresh & Analyze: Charges the battery, rest for one hour, discharge, rest again, then recharges it. Selectable charging and discharging rate.Suitable for batteries stored for more than two weeks but less than 3 month or those showing poor performance.
* Break-In: Also known as IEC capacity measurement and "Battery Forming". Charges battery at 0.1C for 16 hours, rest for one hour, discharges battery at 0.2C, then recharges again at 0.1C for 16 hours. Suitable for new batteries and those stored for more than 3 month.
* Discharge: Discharges the battery at the selected rate.
* Cycle: Performs charge-discharge cycle for up to 12 times with discharge capacity stored in memory. Recharges battery after final cycle.
MH-C401FS, $65
MH-C801D, $140
