thomas_lkt said:If you are calculating the resistor value for a single LED, the denominator should just be IacrossLED, no need to multiply by number of LEDs.
Even if you connect a few LEDs in series, the denominator will still be IacrossLED only.
thomas_lkt said:Usually LED drivers are just some of power regulator. And they still need a resistor as a current regulating device.
Therefore, save some money and use a resistor.
DeSwitch said:ok guys. latest update. I chanced upon a cheaper solution to this ring light. I manage to get hold of 4 mini LED reading light @2.90 each. It consists of 3 Led grouped together, like a mini torchlight with a plastic lens in front. It runs on 3x button type cells but I'm going to modify and convert to AA batteries.
I tested it yesterday and it works better than my 20 Leds. I will post some pictures tomorrow.
The good thing is that it comes with a clip so I clip them on my lens hood and adjust the angle (yes it is adjustable with a sort of ball socket)
Testing at Av at F4, ISO1600 I get the following shutter speed.
With one light ON, I obtained 1/80s, 2 lights 1/125s, 3 lights 1/160 and all 4 lights ON, I get 1/200.
Can anyone help me to calculate how many of these lights do I need to work at ISO400, f8 and shutter speed of >1/100s ?
vince123123 said:Looks interesting - where did you get the lights from?
You mentioned that you intend to convert them to AA power source - I assume that hasn't been done yet? Do you intend to have ALL the LEDs run from the same power source? Or does each LED have its own source.
The disadvantage of a separate power source system however is that you need to switch on all the LEDs one by one - imagine if you have more than 10....
DeSwitch said:My friend got it for me at some budget stores in Bt Batok. Its made in China. I had not seen them anywhere else. He said the store also look like got only a few piece left as I asked him to get 6 pieces more for me.
The battery supply will be link to one source as I dont want to change 30 pieces of button cells. I think 3xAA batt will last me quite some time.
Yup, sure :sweat: :sweat: :sweat: if change all at once.SnapON said:30pcs of button-cell... if u don't mod it u will be :sweat:
