Does all my CF card have to be made bootable and copied with AUTOEXEC.BIN?
when i insert another CF card,..the ISO3200 instantly set back to 1600. :dunno:
all CF card must be made bootable and loaded with autoexec.bin
How useful is spot metering compare to evaulative metering?..
I tried and compare both, like no diff like that eh.. :dunno:
First you must understand what spot metering and evaluative metering are about. Do you?
I have done the procedure again but the problem remains.
My cf card is 4GB but using FAT32 format, so I choosed the 2nd method, and the autoexec.bin seems running ok, but I still got "unable to load update file" error.
Does anyone have any ideas?
Bro his manual book don't have spot metering lah...:bsmilie:
TS, please google spot metering and you will tons of explanation
I followed the instructions and was successful
in running the modified firmware to obtain
the ISO3200 setting, spot metering and shutter count.
The hack seems to be in 2 steps.
i) Testdir.dir
ii) autoexec.bin
It worked for both a 4GB CF under FAT16 as well as
for a 8GB CF under FAT 32.
I cannot be certain if (i) has permanently changed
any part of the original 1.1.1 firmware.
The noise in a ISO3200 image can be made cleaner
with post processing.
For me, too early to say if the hack is really
worth it. ie, need more experimentation.
