sgcamerastore
Zipshot Ultra-light Traveller Folding Tripod for DSLR/DV/DC
Lighten the Load
Photography can require a large amount of equipment if you are wanting to create profession level images and video, which can amass over time and become quite bulky and difficult to transport when travelling between shoots or carrying around with you when outdoors or on holiday. Therefore, it is much more convenient if larger items such as tripods are kept compact in size and keep their weight to the minimum.
This is when you need the Traveller Pop-Up Tripod with its ultra lightweight design, weighing in at only 312g! Also being able to be folded down until highly compact, it is very little effort to carry around on the go either by hand or attached to a bag and can be assembled and ready to go within a matter of seconds, thanks to the quick release elastic cords fastening the legs together. It’s not called the Traveller for nothing!
Outstanding Adaptability
Compatible with a huge range of different cameras including lightweight SLRs, bridge cameras, video cameras and compact digital cameras, the 1/4” threaded mount is positioned on a 3-way ball head. Equipped with a multifunctional 3D pan head to give you universal adjustment possibilities, it allows for a wide range of angles to take the best possible photo with a maximum height of 112cm and a secure and steady hold at your chosen level.
Ideal for capturing shots on self timer e.g. when you want to capture yourself in the shot the reliable and sturdy tripod will allow you to produce professional looking photos of all the family, couples together or yourself against a scenic backdrop when on holiday or an outing. Wherever you are or whoever you are with, Hama will help you to create endless memories that you can treasure as well as pictures that you can be proud of.
Specification:
Very light folding tripod - ideal for lightweight SLR cameras, bridge cameras, video cameras and compact digital cameras
The leg sections are fixed by means of the tight elastic band
When the elastic cords are loosened, the tripod legs open in a matter of seconds (up to a height of 112 cm)
With 3-way ball head including rubber pad
Transport length: 38 cm (folded)
Material: Aluminum
Max. Loading: 1000 g
Thread: 1/4" (6,4 mm)
Colour: Black
Fixed Height: 112 cm
Use: Photo/Video (3D)
Weight: 312 g
Lighten the Load
Specification:
Material: Aluminum
Colour: Black
Weight: 312 g
