Equipment Type: Video Cameras
Equipment Brand: CAME-TV
Equipment Model: x2 190Wh Battery Sony V Mount For Camera Camcorder Battery /w charger
Price (S$): 800
CAME-TV 190Wh Battery-
There is no memory effect, the battery pack can be recharged before being fully discharged. Remaining capacity of the battery is indicated by a LED display. There are multiple intelligent protections inside the battery for safety and reliability.
Model: CM-190S
Voltage: 14.8V
Capacity: 190Wh
Temperature range: -30℃ ~ +55℃
Dimensions: 6.02 x 4.02 x 1.89 in (153 x 102 x 48 mm)
CAME-TV Battery Charger And Power Supply 2 Channel For Camera-
1.This charger is specially designed for V Mount Li-ion camera battery.
2.Can charge two V Mount Li-ion camera batteries simultaneously.
3.Can be used as camera adapter directly.
Input: AC 100v -240V 50HZ-60HZ
Ouput: Charger for one battery DC 16.8V/4A
Charger for two battery DC 16.8V/3A
Adapter 15V/4.5A
Applicability: for V lock Li-ion battery
Dimensions: 240(W) * 140(H) * 60(D) (mm)
Working Temperature: -10℃ - 40℃
Weight: 1.0 Kg
http://www.came-tv.com/cametv-190wh-battery-sony-v-mount-for-camera-camcorder-battery-p-289.html
http://www.came-tv.com/cametv-battery-charger-and-power-supply-2-channel-for-camera-p-412.html
Real Name: V
Contact Number: 94three7476three
Condition of Item: Mint
Warranty Status: Test on the spot
Price (S$): 800
Model: CM-190S
Voltage: 14.8V
Capacity: 190Wh
Adapter 15V/4.5A
Weight: 1.0 Kg
Real Name: V
