WTSell: Tripod - Other SIRUI SVM-145 Rapid System Modular Monopod Tripod
Carlc
Equipment Type: Tripod
Brand: Other
Short Description: SIRUI SVM-145 Rapid System Modular Monopod Tripod
Price (S$): 220
Condition of Item(s): Mint
Barely used, like new condition.
Carrier sling bag included.
Load Capacity: 22 lb / 10kg
Working Height Range: 29.5 to 57.1” / 75cm to 145cm
Folded Height: 29.5” /75cm
One-Step Height-Adjustment System
Modular Head Quick Setup Plate
Removable, Folding-Leg Tripod Base
Two Bubble Levels
Weighs 3.28 lb /1.49kg
Rapid One-Step Height Adjustment】: SIRUI’s new rapid release system is used on SVM series monopod. You can just rotate the twist lock to fast extend or retract the camera monopod. One-step to setup shooting height to 57”/1450mm, you won’t miss any brilliant scene during fast-moving shooting.
【Lightweight Carbon Fiber Monopod】: SVM-145 monopod with 36mm max tube, only weighs 3.3lbs/1.49kg and load up to 22lbs/ 10kg, which is ideal for activity shooting where you can move it easily to capture images at the appropriate angle.
【Modular Design 3 in 1】: The mounting plate, monopod leg and tripod base can be detached and freely combined.This versatile monopod provide 3 options: 1)monopod with adjustable feet, 2) Extension rod, 3) Low angle camera tripod base, to meet different shooting needs.
【Quick Lock/Release Head】: Both the monopod top and tripod base feature the same innovative quick-release system. Pull down the collar to release the top plate or insert the top plate to lock your device automatically. Only 2 steps to switch different devices in seconds.
【Smooth Pan and Tilt Base】: Simply rotate the ball locking knob for damping adjustment or direction locking, the monopod base enable 360°swiveling and 36°tilting in any direction smoothly and stably, which is an extra mini tripod for you.
【Stable Monopod Base】: Designed with stronger structure and the length of feet is lengthened up to 15cm , which make the monopod with feet more stable and reliable to work in different environments.
【Ergonomic Design】: Twist Lock constructed with aluminum alloy and silicone, allows to silk-smooth and quick height adjustment easily. And first tube part is covered with Anti-slip silica gel sleeve and folded length only 29.5 inch, effortless to take it to anywhere.
【Wide Compatible Monopod for Camera】: With innovative one-button release reversible 1/4” and 3/8” screw, SVM-145 can be converted screws quickly and compatible with different heads or DSLR cameras.
【Professional Camera Monopod】: Model:SVM-145 | Material: Carbon Fiber | Sections: 3 | Max Tube Dia: 1.4”/36mm | Min Height: 29.5”/75cm | Max Height: 57.1”|145cm | Retract Height: 29.5”/75cm | Weight: 3.3lbs/1.49kg | Max load: 22lbs/10kg
More photos
More ohotos
