WTSell: Tripod - Manfrotto Manfrotto 715B Digi Tripod with Integrated Ball Head
parameters
Equipment Type: Tripod
Equipment Brand: Manfrotto
Equipment Model: Manfrotto 715B Digi Tripod with Integrated Ball Head
Price (S$): 55
More info here:
http://www.digitalrev.com/en/manfrotto-715b-digi-mini-tripod-blk-wqr-3633.html
Manufacturer Description:
The most compact, full-size tripod in the Manfrotto range and designed for the new compact digital and conventional point and shoot cameras. The 715B which replaces 714B, comes with a micro "dovetail" quick release plate. Manfrotto engineers were careful not to compromise stability for size and weight reduction. The incredibly short folded length of just over 17 inches was achieved with two engineering breakthroughs. First, the leg pivot was re-designed with a unique single hinge allowing the leg to fold shorter than conventional designs. Secondly, an integral ballhead is recessed into the main shoulder casting for transport.
But that's not all! This compact ballhead allows a preset but adjustable tension to be set so that all you have to do is point the camera and shoot. No more locking off handles before you take that shot! This adjustment is done with a handle found on the bottom of the column, set it for your camera and forget it, then just aim and shoot. If you want to lock it down, just turn the handle further and it will lock off the head.
The 715B also features quick-action leg locks for fast set-up and breakdown, and an innovative three faceted center column design prevents any column rotation.
Real Name: w
Contact Number: 97906728
Condition of Item (as per guidelines): 8
Warranty Status: as provided by manufacturer
Package/Accessories/Extras:
rucksack-style bag
