Equipment Type: Tripod
Equipment Brand: Benro
Equipment Model: Camera tripod/monopod/video tripod carbon fiber tripod
Price (S$): fr 219.99 (brand new in box)
Brand NEW Benro carbon fiber tripod for sale.
Benro Tripod C1690TB0 carbon fiber tripod kit: $229.99
Load Capacity: 17.63lb(8kg)
Head Attachment Fitting: 3/8"-16
Maximum Height: 59.25"(150.5cm)
Maximum Height Without Column Extended: 50.78"(129cm)
Minimum Height: 15.55" (39.5cm)
Folded Length: 15.55" (39.5cm)
Tripod Self Weight: 3.02lb (1.37kg)
Benro GA268T GoTravel Series 2 Aluminum Tripod Monopod with B2 Ball Head kit: $219.99
The Quick Flip 90° center column can quickly go from vertical to horizontal without the use of any tools.
Load Capacity: 35.2 lb (16 kg)
Maximum Height: 65" (164 cm)
Maximum Height w/o Column Extended: 54.1" (137.5 cm)
Minimum Height: 18.3" (46.5 cm)
Folded Length: 18.1" (46 cm)
Weight: 4.3 lb (2.2 kg)
Benro KH26NL Video tripod, $249.99
Maximum Load: 11 lb (5 kg)
Minimum Height: 33.9 in (86 cm)
Maximum Height: 72 in (183 cm)
Number of Leg Sections: 3
Independent Leg Spread: Mid Level Spreader
Tilt Range: 90° to -80°
Quick Release (QR) Plate: Slide-In Video (QR11)
Weight: 8.8 lb (4 kg)
Benro C2690TB1 Travel Angel Professional Carbon Fiber Tripod For Camera: $350
Type:Tripod
Sections:5
Max Diameter:28.6mm
Mini Diameter:15mm
Max Height:1630mm
Mini Height:415mm
Max Load:12kg
Folded Length:415mm
Weight (kg):1.68kg
Material:Carbon Fibre
Benro Tripod C2292TB1 carbon fiber tripod kit: $378.99
Maximum Load:12kg
Max Height (24° Leg Angle with Column Extended):1630mm
Folded Length:410mm
Number of Leg Sections:5
Leg Lock Type:Twist Lock
Independent Leg Spread: Yes, 3 stops
Center Column: Included
Quick Release Plate: Arca-Swiss style
Head Mount Thread Size: 1/4" - 20
Weight: 1.61kg
Leg Tube Diameter: 25mm
Real Name: robert
Contact Number: 9.four.6.6.o.1.6.four
Condition of Item: Mint
Warranty Status: 3 month
Package/Accessories/Extras:
original unopened box with all accessories such as bag, tools..
Additional Comments:
SMS only to deal, prefer to deal at bukit batok. Post can be arranged
Type:Tripod
Sections:5
Max Diameter:28.6mm
Mini Diameter:15mm
Max Height:1630mm
Mini Height:415mm
Max Load:12kg
Folded Length:415mm
Weight (kg):1.68kg
Maximum Load:12kg
Folded Length:410mm
Weight: 1.61kg
Real Name: robert
