WTSell: Others - Ulysses Leather Camera Body Suit [for SONY RX1/RX1R]
Equipment Type: Others
Equipment Brand: Ulysses
Equipment Model: Leather Camera Body Suit [for SONY RX1/RX1R]
Price (S$): $140
http://www.ulysses-photo.com/product/2
The full-size compact camera “RX1” is made with all the technology that SONY has. The photograph is presented of the higher beauty one step forward that you can’t believe your eyes. As the homage for their great performance, we also tried to make the challenging body suit that we haven’t made before.
[Slim Grip to Enhance the Hold]
Since the grip part of the RX1 is rather flat, and the space between the grip and the lens is narrow, it is a little hard to hold. However if we attach a big grip, your finger will disturb the hold. So, we put a little acute angle grip, inside of which is special MDF core material, to enhance the grip and concentrate shooting.
[The Hidden Button Under the Suit]
You clearly know the position of the AE lock / zoom button hidden under the bridge of the body suit by the round mark. The button can be operated reliably from only surface pressure.
[The Case is Fixed with a Special Screw]
You attach the body suit to the camera using a special tripod screw. You can fasten the screw with a coin.
[Tripod is Available]
The special screw to fix the bodysuit to the camera has a hole for tripod so that you can use tripod with the body suit on.
[Easily Replace the Battery]
We have adopted a "flip cover" for the case to access the battery compartment simply; it’s not necessary to remove the body suit every time you want and need to change batteries.
[ Specifications ]
Material; Leather, artificial suede, metal
Made in Japan/handcrafted
Real Name: Lim
Contact Number: 96263888
Condition of Item: 10
Warranty Status: NA
