WTSell: Others - Came-TV x2 190Wh Battery Sony V Mount For Camera Camcorder Battery
200sx
Equipment Type: Others
Equipment Brand: Came-TV
Equipment Model: x2 190Wh Battery Sony V Mount For Camera Camcorder Battery /w charger
Price (S$): 1250
Brand New
CAME-TV 190Wh Battery-
There is no memory effect, the battery pack can be recharged before being fully discharged. Remaining capacity of the battery is indicated by a LED display. There are multiple intelligent protections inside the battery for safety and reliability.
Model: CM-190S Voltage: 14.8V
Capacity: 190Wh
Temperature range: -30℃ ~ +55℃
Dimensions: 6.02 x 4.02 x 1.89 in (153 x 102 x 48 mm)
CAME-TV Battery Charger And Power Supply 2 Channel For Camera-
1.This charger is specially designed for V Mount Li-ion camera battery. 2.Can charge two V Mount Li-ion camera batteries simultaneously. 3.Can be used as camera adapter directly.
Input: AC 100v -240V 50HZ-60HZ
Ouput: Charger for one battery DC 16.8V/4A
Charger for two battery DC 16.8V/3A Adapter 15V/4.5A
pplicability: for V lock Li-ion battery Dimensions: 240(W) * 140(H) * 60(D) (mm) Working Temperature: -10℃ - 40℃ Weight: 1.0 Kg
https://carousell.com/p/73418544/
Real Name: V
Contact Number: 94three7476three
Condition of Item: 10
Warranty Status: 1 month
