WTSell: Mirrorless - Sony Sony A6100 BNIB Body only
choc19
Equipment Type: Mirrorless
Brand: Sony
Short Description: Sony A6100 BNIB Body only
Price (S$): 899
Brand New In Box
Imaging
Lens Mount Sony E
Camera Format APS-C (1.5x Crop Factor)
Pixels Actual: 25 Megapixel
Effective: 24.2 Megapixel
Maximum Resolution 6000 x 4000
Aspect Ratio 1:1, 3:2, 16:9
Sensor Type CMOS
Sensor Size 23.5 x 15.6 mm
Image File Format JPEG, Raw
Bit Depth 14-Bit
Image Stabilization None
Exposure Control
ISO Sensitivity Auto, 100 to 32000 (Extended: 100 to 51200)
Shutter Speed Mechanical Shutter
1/4000 to 30 Second
Bulb Mode
1/4000 to 1/4 Second in Movie Mode
Metering Method Center-Weighted Average, Multi-Zone, Spot
Exposure Modes Aperture Priority, Auto, Manual, Program, Shutter Priority
Exposure Compensation -5 to +5 EV (1/3, 1/2 EV Steps)
Metering Range -2 to 20 EV
White Balance Auto, Cloudy, Color Temperature, Custom, Daylight, Flash, Fluorescent (Cool White), Fluorescent (Day White), Fluorescent (Daylight), Fluorescent (Warm White), Incandescent, Shade, Underwater
Continuous Shooting Up to 11 fps at 24.2 MP for up to 33 Frames (Raw) / 77 Frames (JPEG)
Up to 8 fps at 24.2 MP
Up to 6 fps at 24.2 MP
Up to 3 fps at 24.2 MP
Self-Timer 2/5/10-Second Delay
Video
Recording Modes XAVC S
UHD 4K (3840 x 2160) at 24.00p/25p/29.97p [60 to 100 Mb/s]
Full HD (1920 x 1080) at 24.00p/25p/29.97p/50p/59.94p/100p/119.88p [50 Mb/s]
AVCHD
Full HD (1920 x 1080) at 23.976p/50i/59.94i/59.94p [17 to 28 Mb/s]
External Recording Modes 4:2:2 8-Bit
Full HD (1920 x 1080) at 24.00p/50i/50p/59.94i/59.94p
Recording Limit Up to 29 Minutes, 59 Seconds
Video Encoding NTSC/PAL
Audio Recording Built-In Microphone (Stereo)
External Microphone Input (Stereo)
Audio File Format AAC LC, AC3, Dolby Digital 2ch, Linear PCM (Stereo)
Focus
Focus Type Auto and Manual Focus
Focus Mode Automatic (A), Continuous-Servo AF (C), Direct Manual Focus (DMF), Manual Focus (M), Single-Servo AF (S)
Autofocus Points Phase Detection: 425
Contrast Detection: 425
Autofocus Sensitivity -2 to +20 EV
Viewfinder and Monitor
Viewfinder Type Electronic (OLED)
Viewfinder Size 0.39"
Viewfinder Resolution 1,440,000 Dot
Viewfinder Eye Point 23 mm
Viewfinder Coverage 100%
Viewfinder Magnification Approx. 0.7x
Diopter Adjustment -4 to +3
Monitor Size 3"
Monitor Resolution 921,600 Dot
Monitor Type 180° Tilting Touchscreen LCD
Flash
Built-In Flash Yes
Flash Modes Auto, Fill Flash, Hi-Speed Sync, Off, Rear Sync, Red-Eye Reduction, Slow Sync, Wireless
Maximum Sync Speed 1/160 Second
Flash Compensation -3 to +3 EV (1/3, 1/2 EV Steps)
Dedicated Flash System TTL
External Flash Connection Hot Shoe, Wireless
Interface
Memory Card Slot Single Slot: SD/SDHC/SDXC/Memory Stick Duo Hybrid (UHS-I)
Connectivity 3.5mm Microphone, HDMI D (Micro), USB Micro-B (USB 2.0)
Wireless Wi-Fi
Bluetooth
GPS None
Environmental
Operating Temperature 32 to 104°F / 0 to 40°C
Physical
Battery 1 x NP-FW50 Rechargeable Lithium-Ion, 7.2 VDC, 1080 mAh (Approx. 420 Shots)
Dimensions (W x H x D) 4.72 x 2.63 x 2.34" / 120 x 66.9 x 59.4 mm
Weight 0.87 lb / 396 g (Body with Battery and Memory)
Packaging Info
Package Weight 1.43 lb
Box Dimensions (LxWxH) 6.2 x 5.65 x 4.55"
Condition of Item(s): Mint
83835153 Whatsapp
Email:
retroboy19@gmail.com
