WTSell: Flash - Other Nissin MF18 Macro Ring Flash for Sony
Equipment Type: Flash
Brand: Other
Short Description: Nissin MF18 Macro Ring Flash for Sony
Price (S$): 300
Very handy ring flash and model light. Clip on and fine-tune to suit your macro shooting style.
This Nissin model is specifically for Sony Alpha cameras.
Comes with original box, including Adapter Rings for 52, 58, 62, 67, 72, and 77mm Lenses.
In excellent condition. Batteries always removed and flash in dry cabinet when not in use.
"The Nissin MF18 Macro Ring Flash for Sony is a ringlight flash, specifically designed for use with Sony cameras with ADI / P-TTL capabilities. Featuring a Fine Macro mode, this flash provides highly precise light control from 1/128 to 1/1204 in 1/6 EV steps, to achieve the greatest accuracy. When used in manual mode, the flash can be adjusted in 1/3 EV steps from full power down to 1/64th power. The tube flash design is divided in half, allowing you to vary light output depending on the lighting conditions. This design also works in conjunction with the expansion flash head, permitting use of this flash on lenses ranging from 49mm to 82mm in diameter."
Condition of Item(s): 10
