WTSell: DSLR - Sony ILCE-7M2 /A7 M2 BODY
Equipment Type: DSLR
Equipment Brand: Sony
Equipment Model: ILCE-7M2 /A7 M2 BODY
Price (S$): 1550
SENSOR
NUMBER OF PIXELS (EFFECTIVE)
NUMBER OF PIXELS (TOTAL)
IMAGE SENSOR ASPECT RATIO
ANTI-DUST SYSTEM
IMAGE SIZE (PIXELS), 3:2
IMAGE SIZE (PIXELS), 16:9
IMAGE SIZE (PIXELS), SWEEP PANORAMA
IMAGE QUALITY MODES
RAW OUTPUT
UNCOMPRESSED RAW
PICTURE EFFECT
CREATIVE STYLE
DYNAMIC RANGE FUNCTIONS
RECORDING FORMAT (MOVIE)
VIDEO COMPRESSION
AUDIO RECORDING FORMAT
MOVIE FUNCTIONS
COMPATIBLE RECORDING MEDIA
NOISE REDUCTION
MULTI FRAME NR
WHITE BALANCE MODES
AWB MICRO ADJUSTMENT
BRACKETING
FOCUS TYPE
FOCUS SENSOR
FOCUS POINT
FOCUS SENSITIVITY RANGE
AF MODE
FOCUS AREA
TYPE
AF ILLUMINATOR RANGE
METERING TYPE
METERING SENSOR
METERING SENSITIVITY
METERING MODE
EXPOSURE MODES
AUTO (AE) BRACKETING
AE LOCK
ISO SENSITIVITY (RECOMMENDED EXPOSURE INDEX)
VIEWFINDER TYPE
NUMBER OF DOTS
BRIGHTNESS CONTROL (VIEWFINDER)
FIELD COVERAGE
MAGNIFICATION
DIOPTRE ADJUSTMENT
EYE POINT
TYPE
TOTAL NUMBER OF DOTS
BRIGHTNESS CONTROL (LCD)
FOCUS MAGNIFIER
PEAKING MF
FACE DETECTION
CLEAR IMAGE ZOOM
DIGITAL ZOOM (STILL IMAGE)
DIGITAL ZOOM (MOVIE)
LENS COMPENSATION
SHUTTER SPEED
COMPENSATION EFFECT
FLASH CONTROL
FLASH COMPENSATION
FLASH MODES
EXTERNAL FLASH COMPATIBILITY
FE LEVEL LOCK
DRIVE MODES
CONTINUOUS DRIVE SPEED (APPROX. MAX.)
PLAYBACK MODES
PC INTERFACE
NFC™
HD OUTPUT
MULTI INTERFACE SHOE
OTHERS
INTERFACES
MICROPHONE
SPEAKER
COMPATIBLE STANDARDS
CUSTOM FUNCTION TYPE
SUPPLIED BATTERY
BATTERY LIFE (STILL IMAGES)
BATTERY LIFE (CIPA, MOVIES)
EXTERNAL POWER
DIMENSIONS (W X H X D)
WEIGHT (WITH BATTERY AND MEMORY STICK PRO DUO INCLUDED)
WIRELESS & NETWORK CAPABILITIES
Body Only
ILCE-7M2
Body Only
ILCE-7M2
S$ 2,149.00(inclusive of GST)
AC Adaptor
Accessory shoe cap
Body cap
Eyepiece cup
Micro USB cable
Rechargeable Battery (NP-FW50)
Shoulder strap
Sony E-mount lenses
Sony E-mount lenses
35 mm
35 mm full frame (35.8 x 23.9mm) Exmor™ CMOS sensor
24.3MP
24.7MP
3:2
YES
35mm full frame L: 6000 x 4000 (24M), M: 3936 x 2624 (10M), S: 3008 x 2000 (6.0M) APS-C L: 3936 x 2624 (10M), M: 3008 x 2000 (6.0M), S: 1968 x 1312 (2.6M)
35mm full frame L: 6000 x 3376 (20M), M: 3936 x 2216 (8.7M), S: 3008 x 1688 (5.1M) APS-C L: 3936 x 2216 (8.7M), M: 3008 x 1688 (5.1M), S: 1968 x 1112 (2.2M)
Wide: horizontal 12,416 x 1,856 (23M), vertical 5,536 x 2,160 (12M) Standard: horizontal 8,192 x 1,856 (15M), vertical 3,872 x 2,160 (8.4M)
RAW, RAW & JPEG, JPEG Extra fine, JPEG Fine, JPEG Standard
14 bit
Yes
Posterization (Color) Posterization (B/W) Pop Color Retro Photo Partial Color (R/G/B/Y) High Contrast Monochrome Toy Camera(Normal/Cool/Warm/Green/Magenta) Soft High-key
Standard Vivid Neutral Clear Deep Light Portrait Landscape Sunset Night Scene Autumn Leaves Black & White Sepia Style Box
Auto High Dynamic Range (Auto Exposure Difference, Exposure Difference Level (1-6 EV, 1.0 EV step))
Dynamic Range Optimizer (Auto/Level (1-5))
Off
AVCHD 2.0 / MP4 / XAVC S (up to 1920 x 1080/60p 50Mbps)
XAVC S: MPEG-4 AVC/H.264 AVCHD: MPEG-4 AVC/H.264 MP4: MPEG-4 AVC/H.264
AVCHD / MP4 / XAVC S
Audio Level Display, Audio Rec Level, Auto Slow Shutter, HDMI info. Display (On/Off selectable), Time Code/User Bit, Dual Video Rec, Auto Slow Shutter, Record Control
Memory Stick PRO Duo, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo, SD memory card, SDHC memory card (UHS-I compliant), SDXC memory card (UHS-I compliant)
Long exposure High ISO NR
Auto/ISO 100 to 51200
Auto WB, Daylight, Shade, Cloudy, Incandescent, Fluorescent (Warm White / Cool White / Day White / Daylight), Flash, Color Temperature (2500 to 9900K) & Color Filter (G7 to M7: 15 steps, A7 to B7: 15 steps), Custom, Underwater
G7 to M7 (15 steps), A7 to B7 (15 steps)
3 frames, H/L selectable
Fast Hybrid AF(phase-detection AF/contrast-detection AF)
Exmor" CMOS sensor"
35mm full frame: 117 points (phase-detection AF) APS-C: 99 points (phase-detection AF) / 25 points (conotrast-detection AF)
EV-1 to EV20 (ISO100 equivalent with F2.0 lens attached)
Single-shot AF (AF-S), Continuous AF (AF-C), Direct Manual Focus (DMF), Manual Focus
Wide (117 points (phase-detection AF), 25 points(contrast-detection AF)) Zone Center Flexible Spot (S/M/L) Lock-on AF ( Wide / Zone / Center / Flexible Spot (S/M/L))
Yes (with Built-in LED type)
Approx. 0.3m - Approx. 3.0m (with FE 28-70mm F3.5-5.6 OSS attached)
1200-zone evaluative metering
Exmor" CMOS sensor"
EV -1 to EV 20 (at ISO 100 equivalent with F2.0 lens attached)
Multi-segment, Center-weighted, Spot
AUTO (iAUTO, Superior Auto), Programmed AE (P), Aperture priority (A), Shutter-speed priority (S), Manual (M), Scene Selection, Sweep Panorama, Movie
Cont./Bracket: Single, With 1/3 EV, 1/2 EV, 2/3 EV, 1.0 EV, 2.0 EV, 3.0 EV increments, 3/5 frames selectable
Locked when shutter button is pressed halfway. Available with AE lock button. (On/Off/Auto)
ISO 50–25600
0.5"-type electronic viewfinder (color)
2 359 296 dots
Auto / Manual ( 5 steps between -2 and +2 )
100%
Approx. 0.71 x (with 50mm lens at infinity, -1m)
-4.0 to +3.0m
Approx. 27mm from the eyepiece lens, 22mm from the eyepiece frame at -1m-1(CIPA standard)
3.0" type TFT LCD
1,228,800 dots
Manual ( 5 steps between -2 and +2 ), Sunny Weather mode
35mm full frame: 5.9x, 11.7x, APS-C: 3.8x, 7.7x
Yes (Level setting: High/Mid/Low/Off, colour: White/Red/Yellow)
On/On (Regist. Faces)/Off
Still / Movie: Approx. 2x
35mm full frame: up to 8x APS-C: up to 8x
35mm full frame: Approx 4x. APS-C: Approx 4x.
Peripheral shading, chromatic aberration, distortion
Still images: 1/8000 to 30 sec., Bulb Movies: 1/8000 to 1/4 (1/3 step), Up to 1/60 in AUTO mode (up to 1/30 in Auto Slow Shutter mode)
4.5 steps (based on CIPA standard. Pitch/yaw shake only. With Sonnar T* FE 55mm F1.8 ZA lens mounted. Long exposure NR off.)
Pre-flash TTL
+/- 3.0 EV (switchable between 1/3 and 1/2 EV steps)
Off Autoflash Fill-flash Slow Sync. Rear Sync. Red-eye reduction (on/off selectable) Wireless Hi-speed sync.
Sony α System Flash compatible with Multi Interface Shoe, attach the shoe adaptor for flash compatible with Auto-lock accessory shoe
YES
Single shooting, Continuous shooting, Self-timer (10/2 sec. delay selectable), Self-timer (Cont.) (10 sec. delay 3/5 exposures selectable), Bracketing (Cont., Single, White Balance, DRO)
5 fps (in High Continuous Shooting)
Single (with or without shooting information Y RGB histogram & highlight/shadow warning) 9/25-frame index view Enlarged display mode (L: 18.8x, M: 12.3x, S: 9.4x, Panorama (Standard): 25.6x, Panorama (Wide): 38.8x) Auto Review (10/5/2 sec,Off) Image orientation (Auto/Manual/Off selectable) Slideshow Panorama scrolling Folder selection (Date/ Still/ MP4/ AVCHD/XAVC S) Forward/Rewind (movie) Delete Protect
Mass-storage, MTP, PC remote
YES
HDMI micro connector (Type-D), BRAVIA Sync (link menu), PhotoTV HD, 4K still image playback
Yes
Microphone terminal (3.5mm Stereo minijack), Headphone terminal (3.5mm Stereo minijack), Vertical Grip Connector
Headphone minijack
Microphone minijack
Multi/Micro USB Terminal
Built-in stereo microphone or ECM-XYST1M / XLR-K1M (sold separately)
Built-in, monaural
Exif Print, Print Image Matching III, DPOF setting
Custom key settings Programmable Setting
NP-FW50 W-series Rechargeable Battery Pack
Up to 350 shots
Actual: Approx. 60 min. with viewfinder, approx. 65 min. with LCD screen (CIPA standard) Continuous: Approx. 100 min. with viewfinder, approx. 100 min. with LCD screen (CIPA standard)
AC Adaptor AC-PW20 (optional)
126.9 x 95.7 x 59.7 mm
556 g (Body Only) / 599 g (With battery and media)
Downloadable Camera Apps
NFC One-touch functionality
Wi-Fi
Real Name: Selleverything
Contact Number: 92764925
Condition of Item: Mint
Warranty Status: 3 more days
