velasco
Hi guys, I'm using an Olympus OM-1n for a few months now. Everything was fine until yesterday. There seem to be a problem with the frame counter. Sometimes it won't move when i advance the lever.
Can i check with you guys.
a) If no film is loaded , will the number move when we trigger the shutter or will it stay at blank or E?
b) after unloading a film, will the counter automatically move to E or blank? I checked the manual it states this. Whenever the camera back is opened, the exposure counter automatically returns to "S". However, when I opened the back of my camera, it will always go back to blank (the position between E and S) However there were two instances when it when back frame 34 oddly and just won't advance. (there was no film inside)
c) In such a case whereby the frame shows 34 and I need to load a new film, what do I do? Move the lever to S and load a film?
Few minutes ago, I played around without film and advanced 14 frames. However when I opened the back, the counter remained at 14 when it's supposed to reset. I took a few more shots till frame 20. Upon opening the back of the camera, the counter moved back to 16.
Does anyone know what's the problem. Is something stuck inside?
Thanks in advance.
Thanks in advance.
