Artworkfoto
vShop Advertiser
Digital Wireless TTL (CLS) High Speed Sync Power Zoom Flash
for Sony,Pentax,Olympus and Panasonic!
It comes with advanced wireless TTL function compatible with TTL system from all major brands (Canon/Nikon/Pentax/Olympus/Panasonic/Sony; enabling you to use the flash remotely with TTL support.
This flash also includes high speed sync. function, which is recommended at situations where a wide aperture is needed.
Example: Shooting portrait with f1.4/f1.8 aperture while your shutter speed is at 1/2000secs.
Non HSS Flash Photo will be appeared with black bar.
It is well-designed with high performance. It has a guide number of 50(m)! So you can be sure that you get the lighting needed for most occasions.
The built-in reprogram socket allows upgrade of the flash to fit with new camera models. You will have no worry about compatibility of your flash with new cameras anymore!
Features
DPT586AFZ / DPT588AFZ has advanced circuitry built-in, allowing
Compatibility with Canon E-TTL/E-TTL II, Nikon i-TTL, Pentax and Samsung P-TTL, Olympus and Panasonic Four Thirds TTL, Sony Alpha ADI Flash System
Wireless TTL/CLS Function for Digital Wireless Photography
High Speed Sync for outdoor fill flash situations where a wide aperture will be used
Digital Power Zoom and Manual Zoom flash head covering 24 - 105mm position
6 levels of Power Output: 1/1, 1/2, 1/4, 1/8, 1/16, 1/32
2-inch LCD
Bounce 0 / 45 / 60 / 75 / 90 degree
Swivel 180 degree left and 120 degree right
Auto Focus in low-light condition
Red Eye Reduction
Standard Slave
Auto Power Save
Built-in Reflecting Plate and Diffuser
Reprogram socket for update of firmware (when new camera model is out)
Available now!
Features
2-inch LCD
Red Eye Reduction
Standard Slave
Auto Power Save
Available now!
