Hi hi,
I am currently facing a few problems with the making movie process.
I am using Windows XP, Pinnacle Studio 9 .
The problems are:
1) Using Mpeg, the estimate file size and the end-point file size does not tally, in the end, the file is often larger than the estimate
2) When I try to make it in an Avi format, I noticed using different compression codec gives different estimate file size which codec should I use so that it can be played in most PCs or even burned as DVD disc?
3) When I try to make it in an Avi format, using one compression codec, the rendering process freezes at about 21 mins and when I abort the process the whole program hangs Not Responding. And when using another compression codec that gives a smaller estimate file size), the rendering process is so slow that after left to render over night only less then 10mins of the movie is processed.
Are there anything I can do to solve these problems especially #3?
Please note, Im quite a newbie in this and am not really that tech savy . Please excuse my ignorance .
The problems are:
