<Launch> Takeway T1 Clamp-pod mini clamp for mirrorless cameras
Photosphere
A new product to be launched by Photosphere.SG. A mini clamp that's small, slim and light & versatile enough you would want to bring it out with you. Here's some features:
Aerospace Aluminium material
Lightweight (200gr including the ballhead)
Load Capacity of
Ballhead is 3kg (can change into your own ballhead to increase capacity, it uses the smaller 1/4"-20 connection)
Clamp body is 40kg
Jaw has cubic tip for different types of surfaces, smooth, flat, or rugged.
Can clamp cylindrical surfaces from 4-50mm diameter. Flat surfaces from 1-50mm.
Use as an emergency pod (within limitations)
http://photospheresg.com/collections/miscellaneous-accessories/products/takeway-t1-mini-clamp
Here's our flickr album which shows the different application of using it. https://www.flickr.com/photos/photosphere-sg/sets/72157648916697706/
Retail Price - $95
Standard package consists of
- Clamp body x 1,
- Ballhead x 1,
- Smartphone holder x 1,
- Inner jaw x1,
- Pouch x1,
- Base x1,
- Stand x1.
