By Richard Harrington
We’ve all faced the same problem: photographs that lack contrast; images where the shadows and highlights look flat and the details are muddy. While the problem is common, the solutions are many. In this article, I want to show you several easy fixes (using built-in tools) — including some uncommon ones — that you should explore. We’ll also take a look at Aurora HDR, which works as a plugin to both Lightroom Classic and Photoshop.
The Problem
You open up an image and it just feels flat. Your mind doesn’t remember the scene this way, but your camera sure does. What’s the problem? It’s all about dynamic range.
On the left is what the camera can see in a single exposure. The photo On the right, created by merging five exposures in Aurora, is much closer to what my eyes saw.
Dynamic Range Explained
The dynamic range of your photo is the difference between the maximum and minimum values. In simpler terms, are the black points rich and the white points bright? Here’s a simple example where you can see which gradient has a true black and white point.
This image lacks full dynamic range, resulting in dingy blacks and whites.
Proper dynamic range results in FULL coverage from left to right on the histogram.
In most situations, a photo with a wide dynamic range feels rich and deep. Once adjusted, this low-depth image takes on a richer feel. Note that this isn’t just about moving the Contrast slider. It’s about extending the histogram to ensure a full balance.
There are several ways to improve the dynamic range of your images: You can change how you capture your images, change how you process them, or both. There’s no right answer, as it really comes down to how much effort you’re willing to put in and the results you want to get. Toss in the limiting factors of your camera and shooting style and you’ll quickly discover that one size does not fit all.
Why HDR Isn’t a Bad Word
For many photographers, the term HDR (high dynamic range) causes their blood pressure to rise. I encounter photographers all the time who tell me how HDR is awful. A fad. A gimmick. Absolute garbage. They cite garish examples where the colors and details have been pushed to cartoonish extremes.
Sure, if we judge HDR by its worst examples, that’s totally valid. But it’s akin to assuming that Photoshop is only capable of examples like this or this. Don’t blame the tool for a lack of good judgement by the user. For the record, I strongly prefer the third image below.
From left to right: The original exposure calculated by the camera; an image created from merged exposures; the same image lightly adjusted using HDR tone mapping plus Tone controls; HDR gone wild
HDR has been around for a long time. Photoshop CS5 introduced Merge to HDR Pro back in 2010 to create 32-bit files. Lightroom and Adobe Camera Raw more recently (version 6 in 2015) added an advanced option to create floating 16-bit DNG files from several raw images. This feature has received additional updates in Lightroom and now can even be used to create panoramic HDR images.
Using HDR imaging techniques really makes a difference in your photos. If you use the Shadows and Highlights sliders, you’re effectively using a less powerful version of HDR. Why not take these controls further and get even better results? When done correctly, HDR is naturally beautiful!
Let’s explore the options you have built into Lightroom.
Getting proper dynamic range in Lightroom has gotten easier as the application matures. Let’s take a quick look at the built-in options. These all work best with a raw file, so be sure to capture raw in-camera. These days, even smartphones and drones can capture DNG files, which result in superior quality.
Tone Controls: Shadows & Highlights, Whites & Blacks
These four sliders are the key to getting your dynamic range correct. Typically, it’s a give and take. For example, if you pull the highlights to the left to recover, you should pull the shadows to the right to lift.
Presence Controls + Contrast
The Presence controls generally affect the depth and color saturation of the image. I typically combine these controls with the Contrast slider.
If you’re using a newer version of Lightroom (or the Creative Cloud version), you’ll find the ability to merge exposures. The approach here is simple: To increase the dynamic range of a photograph, simply capture more information in the field.
While the exact settings will vary from camera to camera, the general concept remains
the same. Here are the controls on a Canon EOS 5D Mark IV.
In the field: Look for a setting on your camera called Automatic Exposure Bracketing (AEB). This option allows your camera to quickly switch through several exposures while shooting in a burst mode. Most cameras have this feature, but the number of shots and the exposure difference between each shot can vary between models.
In this case, 7 shots were captured using Automatic Exposure Bracketing. Each shot was 2 stops apart, leading to 12 stops of dynamic range. This is more information than the human eye can normally see.
In Lightroom: The process to create a basic HDR image is pretty easy.
Step One: Select the images you want to merge. You can use Cmd/Ctrl-click to choose multiple photos.
Step Two: Choose Photo > Photo Merge > HDR, or press Ctrl+H. A new dialog box will open. After a few seconds, a preview image should appear.
Step Three: Choose the Auto Tone option if you want Lightroom to create an evenly toned merged image.
Step Four: Choose the Auto Align option if you were shooting handheld. Otherwise, you can leave it unchecked.
Step Five: If there were moving objects in the scene (like a tree blowing in the wind or people walking), try one of the Deghosting options.
Step Six: Click the Merge button to generate a new DNG file and add it to your Lightroom catalog.
Step Seven: Adjust this new image like a regular raw file. You should see more flexibility in the dynamic range, however.
Using Aurora to Push Dynamic Range Further
While I’m a huge fan of Lightroom’s HDR toolset, I often want to take things further. For this, I turn to Aurora HDR from Skylum. It’s a plugin that works seamlessly with Lightroom.
You can use Aurora’s Quantum HDR engine to:
While Aurora has been around for many years, the latest version changes everything. The Quantum HDR engine is a technological breakthrough. Not only are the best parts of each photo used when merging, details that are harmful are left out. This means no halos and less noise. In fact, the software use artificial intelligence to recognize key parts of the image and automatically create the best photo. If you haven’t seen it, you just have to give it a try.
Alternative Raw Developer
If you’re facing a tough exposure, there’s an alternative to fighting it in Lightroom. Sure, you could use Tone and Curves and localized adjustments, but that takes time and doesn’t always work. Instead, I just kick the raw file over to Aurora and let it solve things. This approach is really Expanded Dynamic Range photography; the image is maximized from a single raw photo.
Step One: Select the image in Lightroom.
Step Two: Choose File > Plug-in Extras > Transfer to Aurora HDR 2019. The raw image will be opened in Aurora HDR.
Step Three: In Aurora, choose the Color Denoise and Chromatic Aberration Reduction options from the gear menu.
Step Four: Click Create HDR. The full range of details in the raw file will be analyzed and recomposed into a proper exposure.
Here is the new file as developed by Aurora HDR. This image is the default setting with no adjustments made.
Step Five: Feel free to use an Aurora HDR Look to quickly enhance the image, or use the manual controls to dial in the perfect exposure.
Sometimes I get to the end of my workflow in Lightroom and I just want some more pop. The Artistic and Dramatic Looks in Aurora are great for creativity. I also love black and white photography, and Aurora’s support for Lookup Tables (LUTs) makes for compelling black and white conversions.
To apply a Look in Aurora:
Step One: Select an image in your Lightroom catalog that you’d like to enhance.
Step Two: Choose Photo > Edit In > Aurora HDR 2019.
Step Three: In the new dialog box, choose to edit a TIFF image in 16-bit color using the Adobe RGB color space.
Step Four: In Aurora HDR, if the Looks panel isn’t visible, choose View > Show Aurora HDR Looks.
Step Five: Click the Collections button to browse categories or download more Looks.
Step Six: Click on a Look in the browser.
Step Seven: Use the Amount slider to adjust its intensity.
Step Eight: Use the manual controls as desired to further enhance the image.
Step Nine: Click Apply to return the image to your Lightroom catalog.
Five Looks included with Aurora HDR. Only the Amount slider was adjusted.
Developing an Advanced DNG
I love the ability to merge panoramic photos right inside Lightroom. I use it all the time with my drone photographs. Most drones have panoramic shooting built right in. If not, a gentle tap on the control stick will let you pan the drone between shots. Just be sure to capture DNG files for the maximum benefit.
To develop a panoramic DNG:
Step One: Select the panoramic images in your library.
Step Two: Choose Photo > Photo Merge > Panorama, or press Ctrl+M. A new dialog box will open. After a few seconds, a preview image should appear.
Step Three: Choose a projection method. Spherical and Cylindrical usually work best.
Step Four: Adjust the Boundary Warp settings and the Auto Crop to taste to give a full image.
Step Five: When ready, click Merge. A new DNG file will be created.
Step Six: Select the new file and choose File > Plug-in Extras > Transfer to Aurora HDR 2019. The raw file will be handed off to Aurora, where exposure and detail can be maximized.
Step Seven: In Aurora, choose the Color Denoise and Chromatic Aberration Reduction options from the gear menu.
Step Eight: Click Create HDR. The full range of details in the raw file will be analyzed and recomposed into a proper exposure.
Step Nine: Use Aurora HDR Looks or the manual controls to refine the image’s appearance.
Step 10: Click Apply to return the image to your Lightroom library.
While Lightroom offers a compelling solution for HDR merging, it still only creates 16-bit files. These new DNG files are quite useful, but merging with Aurora HDR allows you to create a 32-bit image.
To merge brackets in Aurora HDR:
Step One: Select the source brackets in your Lightroom library. The files should all be in the same format.
Step Three: Choose options in the merge dialog.
Step Four: Click Create HDR to merge the files. The full range of details in the raw files will be analyzed and blended into a proper exposure.
Step Five: Use Aurora HDR Looks or manual controls to refine the image’s appearance.
Step Six: Click Apply to return the image to your Lightroom library.
Step Seven: Take advantage of Lightroom adjustments like Upright and Sharpening.
Now You Try
I’m sure you have images in your library where dynamic range is challenging. Try out the techniques in this article and see if they make a difference. Better yet, the next time you’re shooting, give bracketing a try. And don’t forget to give Aurora a chance. It’s perfect for unlocking the hidden beauty in your photos and gives a huge boost to natural light photographers. The power of HDR can be our little secret.
The post How to Recover Shadows and Highlights Like a Pro—A Guide to Maximizing Details for Any Photograph Using Aurora HDR appeared first on Lightroom Killer Tips.
The Problem
The photo as captured by the camera
The unprocessed image
- Highlights –This adjusts the brighter areas of the photo. Dragging to the left is typically ideal.
- Shadows –This slider works well in both directions. Dragging to the left darkens shadows and to the right lightens them. Typically, I’ll drag the Blacks slider in the direction opposite the Shadows.
- Whites –Use this slider to increase or decrease clipping in the highlights. If the image lacks dynamic range, drag this slider slowly to the right.
- Blacks –This slider behaves similarly to the Whites slider, except it affects the shadows. Drag to the left slowly if the image lacks dynamic range.
- Contrast –While it may seem illogical, I tend to reduce contrast in an image to keep the midtones from getting bunched up. Try dragging the Contrast slider to the left and then using the Presence controls to add back depth.
- Clarity –The Clarity adjustment can be thought of as Contrast 2.0. It essentially adds depth to an image. Be sure to zoom to 100% magnification when using this slider and watch for halos around the edges.
- Dehaze –This is another method for affecting contrast and is useful to remove haze in an image.
- develop individual photos
- merge brackets to a 32-bit file
- enhance panoramic DNGs made in Lightroom.
The original image lacks major detail due to the backlit sky
The original DNG file in Lightroom (stitched from 26 raw files captured by a DJI Mavic Air)
- If you shot handheld, be sure to select the Auto Alignment option.
- From the gear menu, you can remove ghosting and remove chromatic aberration for backlit scenes.
Now You Try
