Digi-cabi Dry Cabinet By Red Dot Photo
Say No to Fungus!! Get your Dry Cabinet now!!
We have many models of Digi-cabi Dry Cabinet for sale!!
AD series
DB36L(30L dry cabinet)
AD50L
AD60L
AD80L
AD80L II
AD100L
AD120L
DB36N (30L dry cabinet)
AD50N
AD60N
AD80N
AD100N
AD120N
AD160N
DHC series
DHC40L
DHC60L
DHC80L
DHC80L II
DHC100L
DHC120L
DHC160L
DHC200L
Feel free to contact us for further queries.
Regards
Edmund | Jon
T: 91131806 | 81885650
E: enquiries@reddotphoto.com.sg
W:www.reddotphoto.com.sg
The Difference between the New AD-xxN series and the AD-xxL series
attachment.php
The difference between the New AD-xxN series and the AD-xxL series is where the hygrometer is positioned in the Dry cabinet. the photo above shows that the AD-xxL series(left side of the picture) have the hygrometer near the the glass panel and it requires the user to put in a single AAA battery. However the AD-xxN series(right side of the picture) the hygrometer is above the glass panel which is similar to where the hygrometer is on the DHC series which is powered directly from the power supply.
Advantage of the new AD-xxN series:
No need to change batteriers for the hygometer as it is power by the dry cabinet itself.
hi can i check whats the difference between dhc and ad series?
Difference between AD and DHC cabinets
AD series uses analogue control (via a dial), while DHC uses a digital setting.
The desired humidty of storage of lenses is between 45-55% Relative Humidity (RH).
Digital control allows one to set the desired humidity level easily while analogue control will require one to be more patient as there are no markings on the dial to indicate the desired humidity level.
So is it to say that DHC series will be more easy to setup instead of AD series need to wait for the actual RH?
Yes.. The DHC series will be slightly easier setup !!
