Azden wireless headphone for monitoring for boardcast
sgcamerastore
Moto dw -05 -new model
It will be launch tomorrow at sgcamerastore booth 6832 -check it out
Sgcamerastore ( Iifestyle Camera Dept )
NO 3 Coleman Street 02-18 Peninsula Shopping Center
Singapore 179804
_______________________________________
Camera Accessories Branch
No 5 Coleman Street #02-18
Excelsior Hotel and Shopping Center Singapore 179805
________________________________________________
sgcamerastore Studio Equipment Branch
NO 3 Coleman Street 02-21 Peninsula Shopping Center
Singapore 179804
Hot sales line : Hp 63362273
Email: enquiry@sgcamerastore.com
MOTO DW-05 2.4GHz Digital Wireless Headphone
DW-05 Features:
2.4GHz, wireless digital transmission: It allows freer and more personalized Monitoring / music listening without Interfering with others.
USB / Analog (3.5mm & 6.3mm pins): two way audio Input, It facilitates bundled applications of all kinds of players.
30 meters effective reception distance: with HI output mode, you could proceed with your activity while listening to the music Indoor.
One Digital Transmitter: It allows usage of several pairs of headphones for audio reception (It requires optional purchase of AZDEN digital wireless~ headphones).
Low Power Consumption Headphone: regular alkaline battery (AAA x2) may sustain more than 20 hours.
Large Size Headphone of 40mm Speaker Unit: heavy and distinct bass sound, clear and bright mediant and treble, It reproduces hi-fidelity of the mediant-bass effects and the original audio sound.
Rechargeable Batteries are adopted for Transmitter: It could sustain 3-6 hours and make convenient outdoor usage. The transmitter can be linked directly to USB port by using USB connection cable for power supply purpose. It takes about 3 -5 hours to be fully charged when the battery Is empty. USB connection cable: can use USB power adaptor and link It to USB connection cable for power supply.
Automatic Sleeping Function: no audio source for about 10 minutes, then the headphones and transmitter will be shut off automatically.
USB connection port applicable to any type of player with USB connection port. Analog audio input with 3.5mm(Diameter) plug pin or 6.3mm(Diameter) plug pin.
Applications
Connect to Computer/ Tablet (ipad) Practice on Electronic Keyboard TV and Audio in the Room
Connect to MP3 Players and Mobile Multiple Sync Music during Sports
View Video Wireless Connect to DJ Mixer Turntable
View Video
DW-05 has many advantages of being wireless
The most common cause of headphones' trouble is “disconnection of the cable, which we do not have to worry at all. Without the cables, it is more comfortable to use for exercising such as jogging.
function to prevent from interferences
With the “pairing” function, the headphone and the transmitter does matching. Even if other wireless headphones are near you, there will be no interferences at all. On the other hand, it allows usage of Multiple pairs of headphones for audio reception. You can share music with others.
The transmitter can be used for more than 6 hours continuously by recharging with USB cables. The headphone can be used for more than 20 hours continuously with two AAA batteries.
High quality sound and long distance reach with 2.4GHz frequency
Unlike Bluetooth, it can transmit the audio data with high quality. Therefore the quality does not drop although it is wireless. Moreover, it has longer effective reception distance than Bluetooth.
Convenient with many useful functions
The headphone itself has a volume controller on the right side. There is no need to adjust the volume of the original sound. With the auto-sleep function, the power will be off if it is not used for 10 minutes. The battery will be saved even if you forget to switch it off.
MOTO DW05 General Specifications:
Mic Type : Dynamic
Driver Unit : Φ40mm
Output Acoustic Pressure Level : 100dB
Impedance : 32Ω
Frequency Range : 20 ~ 20,000Hz
Weight : Headphone (including batteries) 232g / Transmitter 46g
Occupied Frequency Range : 2.4GHz IMS band
Max reacheable distance : 30m line-of-sight distance
Continuous activating time : Headphone 20 hours ( 2 AA batteries) / Transmitter 6 hours (USB recharge)
Accessories : Stereo mini plug cable (gold plate), Stereo standard convert cable (gold plate), USB cable, RCA cable (LR) - Stereo mini jack connecting cable, carrying case, 2 AA batteries (for operation check)
Supplied accessories
Carrying box
USB cable
3.5 mm connecting cable
RCA connecting cable
Jack adaptor
Singapore 179804
Singapore 179804
check this new products at Booth 6832
